hi again Marv,
kinda wish you had asked me a little earlier before you wound the stator.
just to state a few facts. 12 coils per phase can be connected consequent pole (producing 2 poles per coil. it was called "phantom" pole a long time ago).
12 coils per phase can also be connected series pole, which will produce 1 pole per coil.
in order to be 12 pole, or 24 pole, the proper coil spans must be done.
the effective coil span for 12 pole would be 72 slots divided by the number of poles you want. so 72 divided by 12 equals equals 6 ( plus 1 for full span or coil span of 1-7). basically, a coil span of slot 1 and 6 can be used or slot 1 and 7.
for a 24 pole machine, the effective coil span is 72 slot divided by 24 equals a coil span of slot 1 and 3 (plus 1 for full span of slot 1 and 4. which you have). if you wanted to use coil span of 1-3, you would have to use 2 coil sides per slot, and 72 coils.
you have 24 mags on the rotor. assuming they are equaly spaced, and they alternate N S N S N S, you have a 24 pole rotor.
if you wish to use the 24 mags as a 12 pole unit, you would have to group the mags in 2's tight together of the same polarity in order to make a 12 pole rotor. you then would also have to rewind the stator with a coil span of slots 1 and 6 or 7 in order to best match the width of the magnet pole between the coil legs of the coil.
what you have now, is what i really would have selected to do myself with a 72 slot stator. 24 pole machine. it will give you 60HZ at 300 rpm. you could probably transform the output to what you want at 200 rpm (40 HZ).
so i can give you a numbering system to connect for 24 pole if you still want it. skip pole may not be possible with the consequent 24 pole connection (i will have to figure that out to be sure). so please let me know how you wish to procede. it will take me a day or 2 to do it for you with the new year holiday here.
on another note, just curious how you arrived at the number of turns you have per coil. what voltage are you expecting from the machine and at what rpm?. what is your expected output and how will you be using it.
the laminations look skewed. am i correct? and also how did you make the stator? you did an awsum job.
zubbly
