I am putting up a 24v generator geared 11:1 At 350 rpm it is to put out over 500 watts. I will be turning it with boast buster blades. I will be putting a low voltage dump at the batteries. The batteries are 2 volt 105 amp and i will use 6 to make a 12v battery bank.
Do i need anything else? Maybe a diode and what kind. What size wire? The batteries will be running a 300 watt 12 volt heater for a cabin.
Have i left out anything or done something wrong?
thanks,
the spiderlegs
