Author Topic: 4 blade idea  (Read 1880 times)
shmuu102
4 blade idea
« on: February 09, 2007, 05:14:36 AM »
i am just about finished with my 1hp conversion, and i am tossing around blade
design ideas.
im shooting for an 6-8ft diameter, (approx 750 watts, i will know better after run
some tests).
anyway , here is a krazy 4blade idea i had.  If someone could point out the error
in my ways, or at least talk me out of waisting my weekend  sucking sawdust for no
good reason...
this is of course only half of it. two of these would lock together to make the 4 blades.
« Last Edit: February 09, 2007, 05:14:36 AM by (unknown) »
maker of toys
Re: 4 blade idea
« Reply #1 on: February 08, 2007, 10:49:17 PM »
the root of the blade is a bad place for a stress riser. . . .AKA a rapid change in cross-section.  set it to furl early.
other than that, and the reduction in efficiency from the extra blade, it SHOULD work.
I would NOT be the first in line to buy a set, though. Nor would I linger at the foot of your tower.
and because someone WILL ask, I might as well be the one:
what's wrong with the Piggot/DanB hub/blade configuration?
-Dan
« Last Edit: February 08, 2007, 10:49:17 PM by maker of toys »
Re: 4 blade idea
« Reply #2 on: February 08, 2007, 10:53:54 PM »
its been done before here..go for it..
i made a hub for mine--it was a toss up between a hub or two two bladers..
« Last Edit: February 08, 2007, 10:53:54 PM by hiker »
luckeydog
    • Colorado Wind Power
Re: 4 blade idea
« Reply #3 on: February 08, 2007, 11:25:01 PM »
I say go for it.
in my opinion it is not as good as a 3 blade but if you
connect it correctly it should be just as safe as any other blade.
I have seen several other people do the same thing with good results.
the only draw back is the added drag you add to it with the 4 blade.
« Last Edit: February 08, 2007, 11:25:01 PM by luckeydog »
Re: 4 blade idea
« Reply #4 on: February 09, 2007, 06:36:06 AM »
It isn't as strong of a joint ...Why waste your
time making an inferior joint, when it won't take
any longer to make a good one?
  ....No need to be sucking sawdust if you use
renewable energy....Muscle Power! A hand saw,the
sawdust falls to the floor...you can saw boards..
in the kitchen even...
    ( :>) Norm
« Last Edit: February 09, 2007, 06:36:06 AM by Norm »
Shadow
Re: 4 blade idea
« Reply #5 on: February 09, 2007, 07:09:32 AM »
« Last Edit: February 09, 2007, 07:09:32 AM by Shadow »
snuffy
Re: 4 blade idea
« Reply #6 on: February 09, 2007, 09:02:16 AM »
I did exactly that on my 3 meter blades.  I believe the center hub is sufficiently strong.  I epoxied the heck out of the joint.  See my diary photos for more finish pics.
« Last Edit: February 09, 2007, 09:02:16 AM by snuffy »
Re: 4 blade idea
« Reply #7 on: February 09, 2007, 11:15:20 AM »
   2 blades might be ok...but not
4 blades cut in the center?
               ( :>) Norm.
« Last Edit: February 09, 2007, 11:15:20 AM by Norm »
shmuu102
Re: 4 blade idea
« Reply #8 on: February 09, 2007, 11:55:14 AM »
ok, what if the joint was smaller, and covered on both sides by metal plates (bolted on)?
and what if the 4 blades are thinner than the equivolant 3 blade design? ( ie, a smaller, limited chord width)
« Last Edit: February 09, 2007, 11:55:14 AM by shmuu102 »
coldspot
Re: 4 blade idea
« Reply #9 on: February 09, 2007, 03:16:21 PM »
My
$0.02
And Not worth that!
"waisting my weekend  sucking sawdust"
If I was to spend some time making sawdust
I'd for sure be making the 3 blade set-up.
« Last Edit: February 09, 2007, 03:16:21 PM by coldspot »
$0.02
Re: 4 blade idea
« Reply #10 on: February 10, 2007, 07:11:44 AM »
  Yeah my thoughts too...I always have trouble
getting the angles 120 degrees ....but nothing
that duct tape...3 or 4 sticks of special hot glue
 and a big hammer won't fix !
           like Merle Haggard sings....
"Think I'll Stay Here and Drink"
            ( :>) Norm.
« Last Edit: February 10, 2007, 07:11:44 AM by Norm »
