Author Topic: 5 foot composite plug  (Read 1209 times)
paradigmdesign
« on: March 01, 2007, 05:13:02 PM »
Here are some of the photos of the plug for the 5 footer.  Just to mention, it is actually a 4'6" blade, the radius is 5'.  This is the foam part of the plug after its first sanding.  It is still missing the top 4" at the tip.  Now it is time to putty and glass it.
« Last Edit: March 01, 2007, 05:13:02 PM by (unknown) »
paradigmdesign
Re: 5 foot composite plug
« Reply #1 on: March 01, 2007, 10:14:30 AM »
« Last Edit: March 01, 2007, 10:14:30 AM by paradigmdesign »
« Reply #2 on: March 01, 2007, 07:53:15 PM »
looks neat ,
what are the spars made of?
« Last Edit: March 01, 2007, 07:53:15 PM by willib »
cdog
« Reply #3 on: March 01, 2007, 08:03:16 PM »
Looking good!
If I understand correctly this is how you make the mold, or plug as you call it, not what the inside of a finished blade will look like? I guess I'm asking will the finished blades be hollow, or do they have some inner structure?(Yes I will likely lead the class in the stupid question department!)
Thanks for the update,
 Cdog.
« Last Edit: March 01, 2007, 08:03:16 PM by cdog »
paradigmdesign
« Reply #4 on: March 02, 2007, 07:22:34 AM »
Super high-tech balsa dowel rods.  They aren't spars as much as allignment rods.
« Last Edit: March 02, 2007, 07:22:34 AM by paradigmdesign »
paradigmdesign
« Reply #5 on: March 02, 2007, 07:34:46 AM »
Not a stupid question.  You are correct in your assertions.  The plug is used to make the molds for the exterior shell.
The first run of blades will start out hollow after infusion, aside from spar caps, then will be filled with poar foam.  The second run of blades I would like to be hollow with a "rectangular" spar (more for developing designs for larger blades).
« Last Edit: March 02, 2007, 07:34:46 AM by paradigmdesign »
« Reply #6 on: March 02, 2007, 07:48:56 AM »
You seem to be using a different type of foam , what kind is it?
i cant tell by the color
on mine i use epoxy between sections
« Last Edit: March 02, 2007, 07:48:56 AM by willib »
paradigmdesign
« Reply #7 on: March 02, 2007, 10:14:17 AM »
Yes, it is polyester tooling foam.  You can't sand the pink crap, and I was tired of breathing in toxic melting plastic fumes. We are also using West Systems epoxy (plus microfibers) to bond the sections together.
« Last Edit: March 02, 2007, 10:14:17 AM by paradigmdesign »
