Much depends how much work you want to do and can do yourself.
First about any DC Permanant Magnet Motor will produce power when spun. Getting the best one for the job can be tricky, but it does not have to be a certain Ametek motor.
I have a 75lb industrial Dayton motor that might make well over 1KW as a genny with the right blades in a good wind, I paid about $20 for it at a scrap yard, and it works! I am of course saving that one for a specail project later.
I have several others I picked up at scrap yards about 1HP that would do very well, about 16cents lb for them. Agian though, as I am going off grid as much as I can I will probably use those as motors to replace AC motors here on big tools.
If you look around for them you can find allot of motors scrapped that are great and cheap, or from a surplus/salvage store.
You can take a decent AC motor, turn the armature down, add magnets and have a nice genny also. Sometimes you need to change a coil connection inside, sometimes you don't.
If you look through the forum well and willing to do some work to build it, pay a little for having stuff done you can't do yourself maybe, then you could build several types of good gennies for $200 or less.
