Ok, I am testing the new stator. I ended up with 42 turns of #15 wired in star. Before I had 60 turns of 3 in hand #20 jerry.
Now I reduced the airgap from 1 1/8th to 1".
Before when I shorted the leads the blades would stop in less than one second even if turning at 200RPM. Now they will stop fast but not as fast I would say 5 seconds.
Other thing I have noticed is that when I load the mill with a 0.5 ohm resistor the speed will start to drop gradually and will sustain more current across the resistor for 30 seconds or more. Before with the same resistor it will come to a fast halt.
Now the cutin is at about 140-160RPM. I have not seen more than 900mA. This is at about 7 - 9 mph. Dont know how good is that.
I got tired winding 5 in hand so I will get two #14 to make the next stator.
Question:
Could the resistance still be too high and thats why the blades dont just STOP fast when shorting?
The resistance is way lower than what is was before even with a single strand of #15.
