Car alternators use a series regulator. When the batteries get up to voltage, you get an open circuit at the alternator. Then the wind turbine would run free.
So, even though you've been having trouble with dump loads, you'll still need a load of some sort and a car alternator voltage regulator doesn't provide that. I know from experience the 10/12 SI family of alternators uses series regulation, and I suspect it's pretty much universal among cars to use series regulation.
Instead, you need shunt regulation. Some motorcycles come with permanent magnet alternators and the voltage regulator in the stock design is typically a shunt regulator. Harleys, for example. Depending on the year of the bike, it might have single-phase or three-phase rectifiers. Anyway, if you look for a stock regulator from a modern Harley with a high-amp electrical system, you might be able to use that with your DC-520 and avoid all the headaches. I haven't yet done any searching for specs of the bike voltage regulators, but from looking at the dc-520 I thik it puts out less power than a modern Harley alternator.
Even into a dead short, the dc-520 maxes out at only 25 amps. That's less than what the typical late-model Harley alternator is rated to put out (and not into a short, either).
One caveat -- the bike regulators are designed to have a lot of air flowing over them. You'd have to take that into account when considering thermal management issues.
