Author Topic: Hugh Piggot's 8' (2.4m) turbine  (Read 1155 times)
David HK
  • Country: hk
« on: August 11, 2008, 09:55:09 PM »
For those of you that are running copies of the 2.4 metre turbine unit could you let me know what 'size' of amp meter you are using.
I have been looking at some 100 amp units that involve the use of a shunt.
For the information of all readers I am about to finish all the metal work fabrication for two units. I have also made the mould, the coil winder and the AC/DC rectifier box which are innovations over those published by Hugh. All being well I should be able to post a set of very interesting photographs by or before the end of August 2008.
David HK
« Last Edit: August 11, 2008, 09:55:09 PM by (unknown) »
scoraigwind
    • www.scoraigwind.co.uk
Re: Hugh Piggot's 8' (2.4m) turbine
« Reply #1 on: August 11, 2008, 10:49:07 PM »
100 amps might be a suitable size meter for a 12 volt system, yes.  The nominal output is only about 40 or 50 amps but it can certainly go higher at times, depending on a lot of factors.  It's always nice to have some 'headroom' although that does make the meter less accurate at low windspeeds.
« Last Edit: August 11, 2008, 10:49:07 PM by scoraigwind »
BruceDownunder
« Reply #2 on: August 12, 2008, 04:35:37 PM »
Hi Hugh,,  where in Australia can I buy your book ?
have had the earlier one for years ,,have read it maybe 50 times,,
Bruce
« Last Edit: August 12, 2008, 04:35:37 PM by BruceDownunder »
