"goucho" asked about a wind assisted auto. The article was claimed to be an overunity device and locked.
A wind assisted land vehicle is NOT necessarily an overunity device. A tailwind or a sidewind can provide power to help (or completely) propel the vehicle. And such vehicles have been designed.
Now powering it from the headwind IS overunity - which is why sailboats can't sail straight into the wind. You CAN go a lot faster than the wind while pulling power from it. (That's just TSR > 1.) And you can can "sail" at angles that are substantially toward the true wind (easily at 45 degrees to it, for instance) and MUCH closer to he apparent wind.
In fact you go your fastest on the "tight hauled" point of sail where you're going as much into the wind as possible - just before you get TOO close to the wind, your thrust stops overcoming your friction, you slow, you lose apparent wind speed, this costs you MORE thrust, and the whole business collapses leaving you "in irons" and being blown gently backward.
People have played with various kinds of turbine-powering-propellor/wheels arrangements. But it's proven much more efficient (and simple) to do a "linear turbine" with one or a few airfoils (sails) and the vehicle itself as the "rotor".
Examples are sail wagons and iceboats.
Another approach that was played with a few decades back (by Dominos Pizza!) was a linear version of a darrieus turbine. This consited of an arched airfoil on the back of a very streamlined three-wheel car. As the car gets moving the apparent wind starts coming in from one or the other forequarter of the vehicle. As with the Darrieus it attaches to the airfoil, exits almost directly toward the rear, and thus applies a forward (and a sideward) thrust. Meanwhile it provides little drag in a calm because its airfoil shape is pointed straight forward, so it's optimally streamlined.
Don't know what happened to this. But I bet that it proved impractical and/or hazardous due to the side forces and disturbances of the air from passing vehicles and roadside obstacles to the wind.
You'll probably have trouble with both sail and darrieus-blade airfoils on a highway. The speeds are high compared to the wind speed. (With a five MPH crosswind at perfect right angles to the road to provide your power you're talking a TSR of 11 at 55 MPH.) But it might be worth a try.
