Hello all, first post to this board after I stumbled upon it. I've been reading up on making a wind generator out of the GE variable speed ECM motors 1/2- 1 HP on various boards and finally got some time to start on one. I do HVAC work, so getting my hands on used but good ones is no problem. I plucked 3 out of the scrap pile at work last week and began to play around with them. The one in the pic with all of the number/color coded stickers on the windings I actually broke one of the start wires off one of the coils, so it's junk. Figured I'd use it for illustration and if a stator, bearings, or end cap ever go bad I've got spare parts.
I have one wired up like "Jerry" from this board did in some of his older posts, but there's a lack of new information and some of the posts/pics didn't show up or weren't real clear to me, so I figure I'd document my build as I went. I'm at the point now where I'm trying to figure out how to wire the 36 wires coming from the end bell of the motor into three phase so I can rectify it to 12vdc. I've read and am still trying to comprehend star and delta configurations and what works best, but I figured a picture is worth a thousand words for people to explain what works best to wire these things. So my main question is what wires below should be wired together, series/parallel? The start of each of the 18 coils in the pic is an odd number, the end is even. For example phase 1 start is 1, end is 2. Phase 2 start is 3, end is four, phase 3 is 5 start and end 6. Around it goes until you end up back at the start.
I've read two tales of how to wire it up. From my understanding, correct me if I'm wrong, to wire it star, I would wire nut 2,4, and 6 together. For phase 1 (orange) Then I would connect 1 to 7, 8 to 13, 14 to 19,20 to 25, 26 to 31, 32 to 1, and then attach a lead to go the rectifier diode. Phase 2 (blue) would be 3 to 9, 10 to 15, 16 to 21, 22 to 27, 28 to 33, 34 to 3, and to a lead to the next rectifier diode. Phase 3 yellow would be 5 to 11, 12 to 17, 18 to 23, 24 to 29, 30 to 35, 36 to 5, to a lead to the last recifier diode?
I've also read to just wire all the starts and ends of each phase together parallel, 6 in a group. In other words phase 1 orange starts would be 1,7,13,19,25,31. Phase 1 ends would be 2,8,14,20,26,32. Phase 2 blue starts would be 3,9,15,21,27,33. Phase 2 blue ends would be 4,10,16,22,28,34. Phase 3 yellow starts would be 5,11,17,23,29, 35. Phase 3 yellow ends would be 6,12,18,24,30,36.
After these are all tied together six in a bunch, you would tie the ends of all phases together, eighteen in a bunch, and the other 3 groups of six start wires for each phase would go to each of the 3 rectifier diodes?
Any help on the best way to wire it for the most power would be appreciated. I'm at the point right now where I'm ready to build my rectifier and need to get this wired. Welding up a stand, tower, etc.. is the easy part for me, I'm just a visual person and the only way I could think of getting my answer was to post a pic for all to see.
Thanks,
Pat
