Author Topic: unidentified noise  (Read 1061 times)
kitestrings
unidentified noise
« on: November 26, 2018, 12:47:53 PM »
Following the summer slumber with our turbine - we have it furled for a good chunk of the summer - I was frustrated to find we had a new noise.  Generally no new noise is good noise.  This was a audible mechanical clicking, or snapping occurring at less than a one per rev frequency a bit over cut-in, and growing in intensity as the rotor speed increased.
After ruling out any obvious contact points, I started to focus on the end play of the bearings.  It wasn't huge, but I could feel a minor movement when flexing a blade toward, then away from the tower.  After waiting through some good early fall winds, we (my son & I) finally got a day where the weather worked.  We pulled the blades and inspected the (accessible) outer bearing cone and race.  I packed the bearing with grease and re-torqued, following Timken's instructions for a target of .001"-.005".
Done with this step, the noise was noticeably better, but not gone.  There was one other thing I learned though...  The last couple of times I had tried to grease the bearings it seemed to take a lot of force and it was questionable how much went where intended.  I had thought that the chamber was full and, if the grease cap were full, perhaps it was just hard to push by the seal.  What I found, in fact, was the cap was empty.  Next I tried my BIG grease gun, with lots of force this time.  It was plugged solid.  I'd brought a mini-torch up with me, but couldn't bring myself to put an open flame on it given the limited access.  And, what if it caught.  I don't own a grease ram.
You can see in the photos where I'd removed the straight, stock zerk and installed an angled fitting when we built.  I then added an access hole just large enough for the grease coupling.
11523-0
It's at about 10:00 in this photo:
11524-1
This allowed me to grease it, but there really was no access to remove the fitting from the hub casting; not without disassembly.
Then I looked at a spare fitting that I had, and noticed that it was not a single piece, but rater two-pieces with the ball section taper threaded into the angled body of the fitting.
A 1/4"-drive deep-well cleared the access hole and I was able to remove it.  I ran a small wire through the orifice in the casting wall and out came a fair amount of dry, opaque grease residue.  After reinstalling the new zerk I could now freely pump life into the thing.  It made a HUGE difference on removing the noise, and we're back to at least the normal noise(s).  Fooosh, fooosh, buzzz.
I small win that the zerk was made as it was - and I wish I could say that I planned this - but I think we'll take pure luck this time.  ~ks
Frank S
Re: unidentified noise
« Reply #1 on: November 26, 2018, 04:06:27 PM »
Good to hear that it worked out ok. Those xerk fittings cn be a pain to remove when access is near impossible.
« Reply #2 on: November 26, 2018, 10:24:16 PM »
Whether by luck or by genius, if it works, I'll take it.  Enjoy the quiet.  Hum if you know the words.
