I watched to see my wind turbine perform. 25-45mph winds. I don't have the inverter, but I do have the shunt controller and dump load.
The turbine furled at about 25mph - I was going to adjust that to 35.
The dump load and shunt controller worked perfectly, kicking in as the rpm got too high, dumping 1000w as needed. The blades spun well and the tower held. The emergency brake, which I then engaged, worked flawlessly.
I left home and came back and something didn't look right. I had left the wind brake engaged. When I looked up the blades were still locked down, but the tail was gone. The metal tubing had snapped. Since it was held in two places, one must have snapped and then it must have bounced like a flag, chopping the tips of my blades off.
Now I am without blades and tail.
I plant to carve them again, but would like to try something less expensive than cedar. Any suggestions? Fur, pine? I am going to coat them with epoxy so the weather should not be an issue.
If you go to http://www.mindchallenger.com/wind you can see what it did look like. Maybe I can get some suggestions for strengthening the tail.
