Don't you love it when that green LED on the Trace stays on solid?
It's a happy light, and in my setup I don't see it like that often enough.
That's probably a Trace C60, with the label punched beside the C60 number (I know, why can't they just print 3 labels and put the right one on at the factory...)
To find out how it's set up, you have to open the cover (this is one piece of equipment that tells you the warranty is void if you DON'T open the cover).
The setting for 12v/24v is a jumper inside, on the right. There's another jumper that must be moved if it goes from controlling a solar cell to a windmill.
You can download the whole installation manual from the Xantrex website. It shouldn't be too hard to find but it you have trouble, just ask, I'll dig up the link.
Another C60 will be a suitable charge controller for a 10' windmill, though users here seem to have more success with Outback's charge controller, because it's more responsive to surges of current in wind gusts.
Something really important to bear in mind, since you mentioned New Mexico (I assume that is "NM") is that at high altitude, your wind turbine collects less power because the air is significantly less dense. It's a factor you can ignore in a lot of places, but I just happen to know NM has some very high ground levels.
