Thanks Taylor,
My blades are not intended to be flat. They have no twist and the chord is also constant. They have an "airfoil" shape: imagine a 2" x 6" x 2' long piece of wood. It has two 2" x 6" faces, looking at one of them trace one diagonal, now you have two identical right triangles. Cut the piece of wood along this diagonal. You end-up with two "airfoils" 2' long. Of course leaving the right angle as is does not look like an airfoil. So divide the chord into 3 sections, trace a vertical line 1/3 of the way and you get a point in the wood from which to trace a line to the leading edge of the blade. Now you cut the wood all the way along this line.
The shape of the airfoil is still a triangle which can be rounded of by sanding. So I ended up with two pieces of wood that are not flat but not a true airfoil either.
As far as tools, I don't have many for wood working. The cuts are straight forward for the guy at the carpentry shop (they still look funny at you). I'll try to post a diagram or picture latter.
As far as length, I started first with 4'(1.2m) diameter pvc blades and every time I had a failure I replaced them by slightly longer blades. The conversion seemed to like longer pvc blades. Since I don't have any experience with wood blades I decided to start small first because I don't have a furling mechanism yet (pvc blades allows you not to have that I think, or maybe that's why they failed).
