Fieldlines.com: The Otherpower discussion board
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
News:
Oil sucks, wind blows.
Home
Help
Search
Members
View the memberlist
Search For Members
Hall of Fame
Register
Currently debugging, strange errors may occur. Sorry for the inconvenience.
Newbies
Newbies
wonder magnet .com question
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: wonder magnet .com question (Read 1551 times)
artv
Sr. Member
on:
April 11, 2010, 03:51:34 AM »
hello everybody I have a question about your magnet motor experiment .In the exp. you power the solenoid on and off to attract to the mags .My problem is I used an old solenoid off a gm car starter and my wires from battery burned up plus windings on solenoid got very hot ,is there any way to prevent this over heating...........thnx for your time
Logged
Super Hero Member Plus
Re: wonder magnet .com question
Reply #1 on:
April 11, 2010, 09:18:41 AM »
Add more resistance.
A power resistor to limit the current in series with the solenoid, possibly a 5 ohm 50W.
Logged
www.ghurd.info
<<<-----Information on my Controller
artv
Sr. Member
Reply #2 on:
April 11, 2010, 01:05:46 PM »
hi ghurd thanx for the reply .but I thought resistance was the cause of heat I'm trying to reduce it.I should let you know that I'm using a car battery for supply may be this is the problem
Logged
Reply #3 on:
April 11, 2010, 02:43:39 PM »
Power (heat) is I^2R= watts.
Increasing the resistance reduces the amps, which reduces the heat.
The coil has low resistance, so the current is very high.
Check out Ohm's Law, and Watt's Law. That's the 1st place to start for everything.
Logged
www.ghurd.info
artv
Sr. Member
Reply #4 on:
April 11, 2010, 05:11:06 PM »
thanx ghurd been looking over my old school books does that old ryhme stil stand for colour coding resistors can't remember how it goes but can I salvage parts from old equipment ..........what is a 5 ohm 50watt resistor look like......"bad boys something good girls"
Logged
Reply #5 on:
April 11, 2010, 06:10:59 PM »
What gives? Violet.
There are many 'looks' of resistors, but it will be a lot larger than your thumb.
A 25W will be about the size of your thumb.
Logged
www.ghurd.info
artv
Sr. Member
Reply #6 on:
April 11, 2010, 06:39:53 PM »
thanx ........I'll tear into some of my treasures' see what I can come up with .....any suggestions as to what types of old electronic equip. have valuable components ...........I have micro-wave transformers lots of wire caps, resistors,and transistors alll seem small
Logged
Print
Pages: [
1
Go Up
« previous
next »
Newbies
Newbies
