In reply to a couple of posts...
UPS' come in several 'Flavors'... The better, (read: more expensive) ones are 'always online', meaning that the batteries are always both supplying current and recieving it. That is, the wall plug is allowing the charging circutry to keep a charge on the battery(ies), while at the same time, the battery(ies) are supplying current to the step up circutry, with all the power factor correction and filtering that also takes place. This is how a UPS can sometimes 'magicly' clear up a buggy computer. Poor power supply, spikes, surges, droops and dropouts, all are handled well by this sort of UPS. The cheaper 'standby' kind use circutry to 'notice' the total failure of the AC, then kicks in the battery back up. Typical time lags are in the milliseconds range. These type usualy have little to NO filtering or other protections. They use a very simple circut to keep the backup batteries charged, and that's about all. They don't all offer true sine wave output either! Watch out for anything that mentions "Modified Sine Wave"... That's code for a 'stepped square wave', works, sort of, better on some kinds of things than others. (Motors, in particular, don't like anything other than a real sine waveform) The power supply on a computer operates in a 'switching mode', which is to power supplies what digital is to anything else. They can take the 'modified square wave' better.
Another thing to mention: Some UPS' won't work right if no proper ground is present... Using one in a vehicle or the like is often asking for trouble. Also, some of the better UPS' use more than one battery, but in series... So two 12 batts become one 24 volt bank. (My APC brand is like this) The note about cooling and continious duty cycle is well taken... The fulltime UPS' are better adapted for long term usage. The cheaper types usually will self destruct in short order.
I've tried using my inverter (Modified square wave output, 600 watts) in our camper, to keep my UPS charged, (and to prevent the annoying beeping:-) I didn't want to cut the wire to the beeper) to run a small TV/VCR combo running for the kids. No go. Not grounded properly, the UPS refused to work. And this is one that has "DC" startup. (That answering one question, yes, SOME UPS' CAN startup from a 'dead socket' condition) The cheaper ones won't 'startup' from a dead socket, that is, can't self start. Check the maker's web site for your model to see what it can, and can't, do.
Junkman
