Author Topic: Boost Converter Plans  (Read 1108 times)
DanOpto
« on: September 04, 2004, 06:01:05 AM »
Here is a link for a 12 to 24 volt boost converter.
http://www.acs.comcen.com.au/12_24reg.html
« Last Edit: September 04, 2004, 06:01:05 AM by (unknown) »
LEXX
Re: Boost Converter Plans
« Reply #1 on: September 04, 2004, 07:23:43 AM »
I am a total noob when it comes to electronics, but I hope to learn some.  Would something like this be usable with a rectified windmill?  I noticed that the unit had a system for "turning off" the solar panels, this wouldn't work for a windmill so would it need a load diverter before the unit, or am I comparing apples and oranges?
LEXX
« Last Edit: September 04, 2004, 07:23:43 AM by (unknown) »
DanOpto
Boost Converter Plans - Matching Load to Gen
« Reply #2 on: September 04, 2004, 09:09:45 AM »
This could be used to stabilize the voltage output of a rectified mill.
The mill output would be rectified and fed into a very large capacitor that would act as a float storage.
The converter would then dymamically convert the output to a higher voltage to match a higher voltage load that needed an even voltage for it's supply.
You would still need a dump load to absorb over production but the higher voltage would make it easier to match loads.
« Last Edit: September 04, 2004, 09:09:45 AM by (unknown) »
LEXX
Re: Boost Converter Plans - Matching Load to Gen
« Reply #3 on: September 06, 2004, 07:54:37 PM »
Thanks Dan.
« Last Edit: September 06, 2004, 07:54:37 PM by (unknown) »
