Kool.
I will be staying by my aunt in Nassau some time in July, and we are going to spend a week at their house in Spanish Wells. I heard that golf carts are the main means of transportation there too. Sounds fun. Is their much in terms of RE going on in the Bahamas?
Anyway, back to your question. I suppose you could just reconfigure your batteries in 36v banks. I have a couple questions though:
*Are your spare batteries identical? Because if you do create a 36v string, the batteries in the string must be identical, or some will be overcharged, undercharged etc.
*How do your speed controllers work? Are they just adjustable resitors, or are they the fancy electronic type ones? I ask this because one of the simplest ways to charge a 12v bank with a 36v genny (or any power source for that matter) is to put a resitor in series with the power output of the genny. This drops the voltage, but also wastes a lot of energy. If your speed controllers are simply adjustable resistors, they should definately work. The only problem with using resitors is that quite a lot of energy is wasted.
If they are the electronic type, then I guess the only way to find out if they will work is to try. What I would do is connect the 12v battery bank to the output of the speed controller, with an ammeter in series to monitor the rate of charge. Then connect the input for the speed controller to the 36v source, and slowly increase the 'speed' on the speed controller, which, if it will work, should slowly increase the rate of charge on the ammeter. Hopefully this will work.
Anyway, having said all that, I have never used a golf cart speed controller to reduce voltage, so I make no guaranties. Someone please correct be if I am wrong.
Oh yes, by the way, what is internet access like in the Bahamas? Are there places I can go to connect? I heard there is no internet on Spanish Wells. Is this true?
Okay, I'm finished,
Cheers,
Stephen.
