Hello,
I got this Teledyne Geotech 50.1 wind speed sensor from ebay and I'm trying to figure out how it works. If you know anything about it, or if you can figure out something about it, please let me know.
I was hoping the unit is using a reed switch, or is generating a tiny current, so I can count the number of clicks per minute, or measure the current to find the RPM, but I wasn't that lucky.
This unit has lots of electronic components (looks to me like high quality) embedded in a transparent silicon cylinder (#5 in the image below) and it has 3 connectors at the back:
1)+12V
2)Ground
3)Not marked
I applied 12V DC to the unit, I turned the shaft and measured voltage, microamps and ohms between the 1st and 3rd wire and between the 2nd and 3rd wire, but there was no reading of any kind(just some voltage going up/down even when not spinning, probably caused by a capacitor charging?).
Maybe the unit is broken, or the output is far more complex and requires more complex equipment to be interpreted.
Below are few images of the unit taken apart:
When assembled, the wheel #3 gets attached to the shaft inside the cover #2 and the wheel #4 sits inside the wheel #3. The wheel #3 spins around the wheel #4 which is static.
Below is the side view of the wheel #4. It looks like there is a small sensor in the middle of wheel #4, which somehow detects the wheels movement.....
The shaft has 2 small ball bearings and after giving it a good spin by hand, it spins for quite a while, the wheel #3 making a nice little flywheel.
My next step would be to remove al the electronics and add a magnet and reed switch and a bicycle speedometer to measure the cups rpm. I hate to not use all those original components.
Thanks,
Speo
