Author Topic: watt hour meter  (Read 2393 times)
jeffbirkle
watt hour meter
« on: January 12, 2009, 05:47:54 PM »
Has anyone built a watt hour meter for the DIYer?
J
« Last Edit: January 12, 2009, 05:47:54 PM by (unknown) »
tanner0441
Re: watt hour meter
« Reply #1 on: January 12, 2009, 11:34:13 AM »
Hi
Look on EBay I paid about £12 for a DIN rail mounting KWh meter, digital incrementing display down to 0.1 KWh.
Brian
« Last Edit: January 12, 2009, 11:34:13 AM by (unknown) »
Re: watt hour meter
« Reply #2 on: January 12, 2009, 02:06:17 PM »
« Last Edit: January 12, 2009, 02:06:17 PM by (unknown) »
bob g
    • microcogen.info
Re: watt hour meter
« Reply #3 on: January 12, 2009, 02:06:26 PM »
if you are running at 60hz AC the GE digital residential kwatt meters
can be set to monitor watt/hrs as well as about 200 other parameters
and they are cheap on ebay
you just need a meter base to mount it in.
the watt/hr resolution is down to about +- 3 watt/hrs
there is a very simple hack to get them to read out the watt/hrs
and they read to .1 watt/hr resolution,but scan to where the closest i can get is the +
- 3 watt/hrs.
don't know if that will work for what you are after, but is a good option if 120/240
60hz is the watt/hrs you want to monitor.
bob g
« Last Edit: January 12, 2009, 02:06:26 PM by (unknown) »
jeffbirkle
Re: watt hour meter
« Reply #4 on: January 12, 2009, 09:30:35 PM »
Hi all.
Sorry I should have specified a watt hour meter for DC current.
1 for my Wind turbine 1 for my Water turbines and 1 for Solar.
Thanx
J
« Last Edit: January 12, 2009, 09:30:35 PM by (unknown) »
elt
Re: watt hour meter
« Reply #5 on: January 13, 2009, 05:32:39 AM »
IIRC, one of the Dan's had purchased a meter that sounds like what you're looking for... ah, yes, here's the post:
http://www.fieldlines.com/story/2007/7/20/215436/173
Look for the "Doc Wattson".
Hope that helps,
- Ed.
« Last Edit: January 13, 2009, 05:32:39 AM by (unknown) »
kurt
    • website
Re: watt hour meter
« Reply #6 on: January 13, 2009, 10:18:27 AM »
« Last Edit: January 13, 2009, 10:18:27 AM by (unknown) »
JSNH
Re: watt hour meter
« Reply #7 on: January 14, 2009, 11:13:29 AM »
http://www.hialeahmeter.com/siphwame.html
The above link go to a company that remans watthour meters. The cost is pretty low.
« Last Edit: January 14, 2009, 11:13:29 AM by (unknown) »
Re: watt hour meter
« Reply #8 on: January 15, 2009, 01:13:07 PM »
There are some PIC (Programmable Integrated Circuit) types that you can build yourself.  Try www.thebackshed.com   I think they feature a project, with schematic.
« Last Edit: January 15, 2009, 01:13:07 PM by (unknown) »
