I checked out the genny, measured everything, all is fine. The problem was a bridge rectifier which was used had for some reason shorted internally, which can happen. As soon as I did the tests and removed the bridge everything returned to normal. Your generator is fine just to let you know! wiring is good. see you in a couple days.
Good Luck!
Fred.
