Don't feel bad I just came in from completing my newest motor conversion, at about 1000rpm I get 13Vdc no load and about 8Vdc running a puny little dc fan. Bummer
You know of course if you wire for higher volts your amps should say the same, not increase, and if you wire for higher amps then or voltage stays the same and does not increase.
So depending how you wire you can have 140VDC at 3amps by adding enough 3amp coils to make 140V, amps won't change. If you add 2 stators of coils then you can have 140V each added still equals 140V but your can double amps, 3amps each equals 6 amps.
Kinda sounds like you have it about right to me maybe the way I read it.
How many volts are each coil? About 35V? 4 coils = 140V, 2 sets of 4 = 3amps each making 7amps?
Otherwise I am not sure how you went from 3amps up to 7amps? If all 8 coils are series they should be 17.5V each to make 140V, but I think you would still only have 3 amps not 7amps.
Course if this is linear then I am not taking into account if the end coils do less volts or amps either one or even both.
"I have 50 wraps of #14 wire per coil.."
You say your getting 3amps from that, but how many volts per coils is it?
