Author Topic: Charge Controller ?  (Read 898 times)
Hank
Charge Controller ?
« on: October 25, 2005, 09:02:46 PM »
Can you set up two or more charge controllers in parallel to handle more current?
Currently I'm using a C40 which is rated for 40 amps but will take occasional 80 amp spikes. I'm looking to upgrade to a higher capacity controller but it appears there is limited availability.
Anybody have any experience with this?
Thanks,
Hank
« Last Edit: October 25, 2005, 09:02:46 PM by (unknown) »
Cinosh07
Re: Charge Controller ?
« Reply #1 on: October 25, 2005, 03:58:53 PM »
Hello,
For my side, i can respond yes to this question.
I use 3 homemade charge controler to handle the overpower of my genny.
I have set each of them to start the diversion at different voltage.
« Last Edit: October 25, 2005, 03:58:53 PM by (unknown) »
sandovalch
« Reply #2 on: October 25, 2005, 04:23:09 PM »
I would say also YES, but it would me more a matter of adjusting your voltage for both of the controllers, otherwise one controller would cancel out the other one.
Christian
« Last Edit: October 25, 2005, 04:23:09 PM by (unknown) »
georgeodjungle
« Reply #3 on: October 25, 2005, 10:23:40 PM »
i'm using a relay instead of 2 controllers.
« Last Edit: October 25, 2005, 10:23:40 PM by (unknown) »
