I had never heard of an Iota charger, thanks Tom next time I need one I will look that brand and check it out.
I second the idea of a seperate charger for grid charging. You could build your own or buy one, but I think I would keep it seperate from the Xantrex C30. If the C30 is a charge controller and your feeding from the grid, what happens when the batteries ar full charge? Does it shut off the power or send it to a dump load? Would be kinda wastefull to be dumping grid power
My mina thought is if a home built charger shorts or fries etc.. I would not want to take out the C30 with a problem. Might be unlikely, thought it could happen maybe.
Most of the retail chargers are getting into the "Smart" garbage. They monitor the battery and adjust the amps, won't turn on unless the see the battery conected etc...
Not sure if one of those would even work on a C30 or such and no need anyway. The charger itself controls the amps based on battery state of charge.
You could build a manual charger, capacitor to limit the amps, rectifier to convert to DC, this would set the charging amps to a max limit based on the cap, the battery holds the volts down untill it reaches full charge. You have to watch something like this close, after batteries reach the charge the volts will try to climb to 120DC and fry batteries.
Normal retail charger, turn it on and forget it (if not a smart charger).
If a smart charger, watch to be sure it does not go off because of some goofey error or a grid power glitch. That what I hate about Smart Chargers, I get random goofey errors and they shut off at times for no real reason. They won't turn on with a totally dead battery, like leave the car lights on all day, have to charge the battery first like jump start the car, then use the charger. And they turn off with any power failure of a few seconds (we have alot of those) and they have to be manaully turned back on agian, so if not home to watch it they may turn off in the morning with a power glitch and all day they have not been charging.
The power glitches here are often enough I plan to run my smart charger from a UPS when I get another large UPS.
I would charge seperate from the C30 in any case myself and just use the C30 for the RE charging.
