Author Topic: 110v inverters in series for 220v?  (Read 2667 times)
ArmedAndDangerous
« on: December 07, 2007, 03:48:49 AM »
I'm pretty sure the answer is no...but I want to ask anyway. :) Would it be possible to wire two 110v power inverters in series to get 220v? I was thinking maybe I could use the hot wire from both inverters and then use an earth ground as "neutral"?
« Last Edit: December 07, 2007, 03:48:49 AM by (unknown) »
rmiller021
Re: 110v inverters in series for 220v?
« Reply #1 on: December 06, 2007, 08:59:40 PM »
Here is an old post that covers this topic
http://www.fieldlines.com/story/2007/6/4/14837/36517
Rob
« Last Edit: December 06, 2007, 08:59:40 PM by (unknown) »
Opera House
« Reply #2 on: December 07, 2007, 04:05:15 AM »
There are two problems.  The waveforms would have to be synced to each other and most cheapo inverters can no operate with a battery terminal connected connected to the output.  I am at a loss of how to explain this in less than 2,000 words, but even if you could sync them it wouldn't double the voltage.
« Last Edit: December 07, 2007, 04:05:15 AM by (unknown) »
kurt
    • website
« Reply #3 on: December 07, 2007, 12:48:44 PM »
some very expensive inverters can be bridged together for 240v operation but they have to be designed to do that from the get go. if you try it with 2 cheep inverters you will get smoke and flames.
« Last Edit: December 07, 2007, 12:48:44 PM by (unknown) »
ONEmule
« Reply #4 on: December 11, 2007, 07:38:33 PM »
 The term is stacking, and yes you can do it, but as previous post they must be set up for this.
« Last Edit: December 11, 2007, 07:38:33 PM by (unknown) »
