Author Topic: Filter for freq measurement with DVM [CLOSED]  (Read 908 times)
mgtd
« on: November 19, 2008, 03:29:16 PM »
In another recent post of mine, suggestions were made that filtering the raw AC would be necessary to obtain readings using a DVM with freq. capabilities.  I have on order an Elenco model LCM 1950 with autoranging frequency to 4 Mhz.  Resolution is supposed to 1 hz.
Can Flux, or others, provide a simple diagram of the filters proposed with component designations.  I'm not an electronic whiz and could use a little more direction.
I hope to get some meaningful output readings from my 10' Otherpower, at known windspeed (Lacross anneometer below turbine)and RPM of turbine (DVM w Freq capability).
If I'm sucessfull, I post and share.  Mill is almost ready to go back in the air after stator rebuild and other mods due to burnout a few weeks ago.
Makes much more sense to discuss this in the original post rather than spread it all over.
« Last Edit: November 19, 2008, 03:29:16 PM by (unknown) »
Re: Filter for freq measurement with DVM
« Reply #1 on: November 19, 2008, 09:11:45 AM »
Something that goes to 4Mhz is going to pick up every spike and harmonic going.
Try connecting a .22uF capacitor across the meter input. Connect the common lead to one lead of the ac in to the bridge and from one of the other ac leads connect a 47k resistor to the meter active terminal ( capacitor connection).
If it is still neurotic you can increase the capacitor or resistor as the meter will not need many millivolts to operate.
« Last Edit: November 19, 2008, 09:11:45 AM by (unknown) »
