Author Topic: wiring Suresine 300 in house  (Read 1201 times)
otp9999zz
« on: December 28, 2009, 06:04:00 PM »
I had this in car and had the Negative and ground lugs attached to the Neg. battery terminal. Where should I put that wire in the house? Can I leave it off?
The plug on the other end will be grounded..  is that good enough..??
« Last Edit: December 28, 2009, 06:04:00 PM by (unknown) »
independent
Re: wiring Suresine 300 in house
« Reply #1 on: December 30, 2009, 12:04:04 AM »
Sounds dangerous. Wait, don't do anything yet. Please explain exactly what you want to do as there isn't enough information in your post
« Last Edit: December 30, 2009, 12:04:04 AM by (unknown) »
« Reply #2 on: December 30, 2009, 04:52:10 AM »
The ground wire for the House circuit and the Ground Lug on the inverter should go to Earth Ground. Do Not connect any Ground & Neutral wires together. If you are planning to switch this house circuit between Grid & Inverter it gets a bit more complicated. What Exactly are you trying to do ?
« Last Edit: December 30, 2009, 04:52:10 AM by (unknown) »
otp9999zz
« Reply #3 on: December 30, 2009, 04:17:56 PM »
cant ground the big DC ground lug to house earth ground/pipe. Its not possible here.
I am going to leave it off. It will still work. I grounded the inverter/outlet to a ground wire from an adjacent house outlet.That goes to earth ground/pipe.
The inverter system is totally separate system. I cant run a 30 ft fat wire... no way.
« Last Edit: December 30, 2009, 04:17:56 PM by (unknown) »
