Thought that my research might be of use to others....
Building a 100A 16-32v charger, winding my own transformer.
I'm in the process of building a good sized charger, and have the good fortune to be living in a country where winding transformers, motors, and generators, as well as building inverters (trace DR series copies, mostly) is done commonly by many small 1 man shops located throughout the towns, villages, and cities.
As such, it has been relatively easy to acquire the info and materials required.... and it strikes me that this might be of use to other members. I could have just about anything wound here, at a cost similar to an off the shelf unit. Is anyone needing unusual transformers?
as for my project, so far:
3.6kva core
8 lbs copper magnet wire
nomex paper
wire varnish
nomex sleeves
Cost to build a 3.6KVA (parts only) 80 - 260v to 12-40v (100A or 200A, depending on voltage) transformer, approx $150USD.
Anyway, I'll update this thread as work progresses....
