Or maybe use a sawsall with a long blade and maybe a rail on the opposit side to keep the blade flat
I used a sawsall a lot for my blades. It definitely cuts down on the time.
I bet someone could make a set of blades pretty fast with a bandsaw/sawsall, a spindle sander, and a beltsander/hand sanding.
For Dragonfly III, I good place to start the blade after you have your square board is to cut the flat side/ wind facing side first. Then go on and cut the airfoil by connecting the leading edge and the trailing edge. It is really quite easy.
For your first blade set, it might be a good idea to have a non-twisted blade and/or skip the angle that makes the narrow tip. Or, just follow some pictures of someone else's blades ( I am sure there are plenty of volunteers on here that can help you in that department.)
