Author Topic: Tristar + Xantrex Charge Controllers  (Read 3567 times)
« on: August 07, 2010, 01:45:23 PM »
This weekend I installed a new Tristar TS-60 charge controller.  The Tristar was a very easy switch from the Xantrex C40 - all the wire terminals match up and so do all the mounting holes.  Seems Morningstar knows who their competition is!  I've planned an upgrade from the 40-amp Xantrex for a while - considering either the Xantrex C60 or the Tristar TS-60.  Since the "60-amp" Xantrex is de-rated to only 48 amps in diversion control mode, the decision swung in the Tristar's favour.  It will better handle the incoming wattage from the next turbine I put up.  No wind since putting it on, so I can't report it working or not.
After installing the new Tristar (which went smoothly) I noticed the other C40 (for my solar panels) going a little crazy.  At first I didn't know if I was seeing the famous "edge-of-cloud" effect which magnifies sunlight intensity and gives you a few percent more power.  Once the C40's display crept up from 9 amps (the short circuit current rating of my panels) to 12 amps, I knew something fishy was going on.  I unplugged the C40, and after resetting it, the readings went back to normal.
Has anyone else seen this kind of weird thing happen?
