Today I decided to try out running my laptop off my solar panel. Obviously I couldn't just hook it straight to my computer, so I got out my other toys and took over the kitchen table
Parts Included:
15 Watt Northern Tool Catalog Solar panel ( I rate it for about 11 watts peak at my house ).
8 - 2500 mah NIMH AA Energizer cells
(4) 2000 mah NIMH AA Radio Shack cells
(2) Craftsman Multimeters (one volts, one amps)
400/750 watt Black and Decker Inverter
several sets of alligator clips that work
Lenovo W500 Laptop set on Superpower savings mode, low screen brightness, and stopped the battery from charging
4 cell battery charger that plugs into 110ac, charges at 500ma.
The load during my tests were either the battery charger or the laptop. The inverter + the charger pulled about 1.1 amps and the laptop + inverter pulled about 2 amps, varying from 1.8-2.4 amps.
Initially, I had charged the AA batteries all of the way, making the battery pack stand at over 15 volts, in which the inverter did not like, so I had to hook up the laptop for a while to drag the voltage lower.
When running the laptop, the voltage at the batteries was about 12.5 volts, but the voltage at the inverter was only 11.8 v, probably due to my amp meter being in the loop. The solar panel was pumping in no more than 0.71 amps, so the load on the batteries was from 1.3 to about 1.8 amps for a good hour or so.
Here are some pictures. The solar panel was on the deck.
Here is a video of the set up:
http://www.youtube.com/watch?v=o5zID6w7Uf8Here is my old video from last year powering my laptop without the solar panel:
http://www.youtube.com/watch?v=Isswvcz7Mcg
