bob-
have you removed the brake yet? i've got a fanuc motor close to being a mill. had to remove the brake from it. it's a bit tricky to do it without removing the magnets from the coils. (i've heard that if you do this the servo can lose a lot of its power)
mine is a 2000rpm 140volt 20amp unit. i decided on an 8.5 foot dia. three blade prop, though i haven't flown it yet.
your will get a very low cut in rpm for a 12 volt system. mine hit 12 volts at 120rpm on the bench, and yours is even a higher voltage, so you may hit battery charging voltage below 100rpm even.
did you get that motor on e-bay for $4.25 + 35.00 shipping? i meant to bid on that one and forgot to, but was astounded when it went for $4.25.
i would think an eight footer would easily hit 100rpm and give you more constant power in lower winds, but if i put that large a prop on that motor, i would enact a furling system for sure. (don't trust me though, i haven't finished my first mill yet)
let us know what you do!
adam
