hi friends,i have a coupe of question concerning discharge of batteries.
i have a deep cycle batteries rated 12v and 100a/h and is connected to wind turbine and solar panels.
what i understand by 12v and 100a/h is that the battery will provide a max of 100amps in 1 hour at 12v and after 1 hour,the charge of the battery will be 0%.if i am wrong please correct
now make as if 1 day the battery is fully charged and i disconnect the charging source and intend use 80% of the battery power leaving 20%for the safety of the battery
80% of the battery charge is 960watts. if i connect my computer which consumes 320watts to the battery through the inverter,does it means that i will be able to use it for 3 hours (3x320=960) until the charge of the battery reaches 20% ?
another question,if the battery is rated 100amps /h at 12v,does it mean that it will give 100A in 1 second for 1 hour or does it mean that it will give a total of 100A in 1 hour at 12v?
the third question,for example a led bulb is rated at 3w,is it 3w per hour or 3w per second, making it to consume 3wx3600s=10800w?
thanks
