Author Topic: my dump controller  (Read 33915 times)
XOKE
Re: my dump controller
« Reply #66 on: December 09, 2010, 03:44:38 PM »
HI guys
About the charge voltage for my batteries I have tested for 3 days in a very good wind, (sometimes more than 12 m/s) and when they are at rest the voltage don't go up than 12,56 volts,(about 90%)  so for charge this batteries I need more voltage.
I try another source of information, I found the web page of then, send a mail explain this situation and their answer is that I should charge the batteries at 14, 4 volts, because there's a cycle of charging and discharging.
Well next few days when I get home again I`ll set the controller to 14, 4 volts and check it one more time.
xoke
XOKE
« Reply #67 on: May 02, 2012, 07:25:07 PM »
HI, I made some new improvements in my dump box; I add a few more resistors, now there are 15 of them.
Now I can dump at 14,4 volts around 1300 watts,
This works fine, last night there's a lot of wind and the battery bank its full charged, and it was dump most of the time, and the resistors get a little warm.
regards
xoke
« Reply #68 on: May 03, 2012, 09:52:16 AM »
VERY nice! any possibility of adding a small DC fan to move the air around them to help with heat dissipation? Even one on the outside of the gridded door ?
Still VERY nice!!
Thanks for the update.
XOKE
« Reply #69 on: May 07, 2012, 07:10:43 AM »
Thanks Bruce S.
I believe theres no need any addicional fan, the box its big enough 50cm x 40cm x 15cm.
thanks
regards
opo
  • Country: mx
    • homepage
« Reply #70 on: May 07, 2012, 11:17:19 AM »
Very nice set up!
  Congratulations
Octavio
http://play.google.com/store/apps/developer?id=opo Check my apps aFoil and aFoilSim on android market.
  • Moderator
« Reply #71 on: May 12, 2012, 07:06:02 AM »
Very nice!
