I like Chris idea in the turbine transmission getting away from trailer hubs . Has any one tried a different idea with just a direct drive mill I don't see me rebuilding this one with a trailer hub
Jarrod, I have build several direct drive turbines similar in design to a Proven with a rear mount generator on the mainshaft.
You're an ASE certified tech so you'll understand what I'm talking about here; in an automotive application the trailer spindles everybody is using are designed to carry the majority of their radial loads on the inner bearing. That's why it's bigger than the outer one and why the wheel is offset, etc.. You put this on a wind turbine and it's all backwards. Now you got the small outer bearing carrying most of the radial load and it's impossible to keep bearings adjusted properly because the hub and bearing assembly is being use for something it was never designed for. It's a bad design from the word "go". It works on smaller turbines, but once you get to the size you got I wouldn't even consider it. You don't see Vestas building turbines by cobbing a spindle and hub off a CAT end loader and hanging 274 foot blades on it. They got mainshafts with bearings that can handle the loads.
Secondly, using a transmission or direct drive design with the generator on the rear of the mainshaft distributes the loads better over the structure of the turbine head. On my 12G machines the distance between the front and rear main bearings is 13.620" and the front bearing alone is rated at higher radial and axial loads than your whole 7500 lb trailer spindle unit.
To gain a basic understanding of how your loads are distributed on the turbine head and bearings, take a 2 x 4 and place it on a fulcrum of some sort. Then place a weight on one end of it. Now, try lifting that weight by pushing on the 2 x 4 only 4" or so from the fulcrum, then try it at 13-14" from the fulcrum. This is a good demonstration of the loading on your bearings on your trailer spindles vs my geared machines with a wide spacing on the bearings and a long input shaft.
Add to that the fact that the loads are transferred to a massive transmission case that can be run over by a D-9 dozer without hurting it, and the fact that the transmission case transfers loads to the tower over 12.7" of the yaw tube instead of a just a little offset pipe or tube with gussets, and you got a much stronger and more durable machine. With the geared unit the loads the rotor transfers to the transmission and tower are also separate from the generator because it's on a different shaft that's spinning at much higher speed. So the generator is much smaller and lighter. This allows balancing the machine on the yaw shaft so it's slightly nose heavy static, but in normal operation rotor thrust balances the machine on the yaw shaft to minimize wear and loading on the shaft - again improving durability and longevity of the machine.
Now I'm sure people are going to claim the current homebrew designs are adequate because they've never seen one break. But because of how they're designed, and the way loads are transferred to the structure, they flex in 60+ mph winds. And you know what happens to a trailer spindle that is flexed by being overloaded - it eats bearings up because tapered roller bearings have to run in PERFECT alignment or the outer race and rollers get galled and everything goes downhill from there.
I supposed it will be discussed ad nauseum while you're having bearing failures and how you're doing this and that wrong, etc., etc., etc.. But it's not even a mystery to me. The problem is in the design. You're flying a design that can not handle the loads in 60-80 mph winds with a 20 foot rotor hanging on it. Period.
Email me offline and I got plenty of pictures I can send you of machines I have build using a direct-drive design similar to Proven's. As flux noted, building a geared unit requires some engineering and machining facilities that are beyond most homebrew shops. But a direct-drive that doesn't use a trailer spindle is quite easy to build and you can re-use your existing generator rotors and stator, etc..
Chris
