Say I have two identical off-the-shelf 12Vdc-to-120Vac inverters, and want to synthesize one 24Vdc-to-ac inverter out of them.
“Identical†is the key word here, these two inverters must have the same topology, component tolerances, and internal timing delays.
The benefits of doing this are obvious, if you already have 12v inverters on hand and want to build 24/36/48v systems without using dc-dc converters.
Not knowing much about inverter design, I am sure I've gone badly wrong with my reasoning below, but where, can someone point out?
I connect the two 12v inverters in series on the dc side, and tie them to a 24v dc source.
I connect the inverters' ac outputs in parallel (L1 to L1 and L2 to L2).
Perhaps some external isolation/blocking circuit would also be needed at the inverters' ac outputs, or not because this may interfere with the ac feedback, see below?
I tie the inverters' on/off switches together to ensure identical turn-on transient timing.
On the dc input side, the mosfet collector currents should be the same in both inverters, as these inverters see the same ac load, and operate with the same pwm controls and timing?
However, each inverter's H-bridge would see 12vdc across it, and not 24vdc?
On the ac output side, the voltage and current phasors from both inverters should add in-phase.
The two inverters see a common ac load, so the feedback from common L1 and L2 to the pwm controls in both inverters should be the same, ensuring mosfet control synchronization in both inverters.
This cross-feedback may also cause any phase errors between ac outputs from both inverters to be driven to 0, ensuring ac outputs synchronization (because each inverter sees the other inverter's ac output, and its own).
If this scheme flops, are there any other schemes possible to accomplish this goal?
