Greetings, ...
I will try to hack through some confusion here in a short summary, but be advised I am not in a great mood.
The whole thing could be proved with one test coil, one RPM, and a calculator, in 1 minute.
#1. Those findings 111% completely agree with what we said. It would be far less confusing if the "X in hand" were ignored.
#2. So does "the electric brake action".
#1A. Ignore the 1~8 in hand, and look at the voltage per turn. They are the same.
#2A. Less resistance and shorted makes a better electric brake. And 8 in hand has only 12% the resistance of 1.
#3. The flux path in the photos of the lathe test is totally incomplete, and even less complete than than the "working version".
I doubt the test results shown prove anything relative, except that in the same magnetic field, doubling the turns in a coil doubles the unloaded voltage, which everone knows.
#3A. Shorting a coil with the same number of turns and a lower resistance will make "the electric brake action" more pronounced, which everyone knows.
#3B. AWG# minus 3 = Two in hand. Two #22 in hand = one #19. Four #22 in hand = Two #19 = one #16.
#4. Everything in #3 was common knowledge 100 years ago. Maybe >125 years ago.
You can do some
VERY fine worksmanship on the materials and assembly, but you need to read and comprehend what people point you toward.
#1A1.
Volts per turn per RPM. is the same in the same magnetic field.
1.3V / 200 turns / 200RPM = 0.000,032,5
0.16V / 25 turns / 200RPM = 0.000,0032,0
The result is closer than the margin of error, and closer than the meter can read?
(personally, I am sort of impressed they came out that close under the test conditions, though I won't expand on the concepts)
Congratulations? You spent a great deal of time, money, and resources, to prove what we were telling you months ago.
