I have thought about what performance I may be able to get after I find the best blades for how my alternator is loaded now. I wondered if there would be much to gain after I open the air gap a bit. I have thought that once I open the gap, that the blades that performed best before air gap adjustment, may not be the best match after I tweak the alternator.
At least when I get to that point, I'll know...
![Smiley :)](https://www.fieldlines.com/Smileys/default/smiley.gif)
Like I said, when I set this up, it was adjusted to cut in at 120 rpm. Up on the tower it seems to cut in below that so I am sure that the air gap needs to be opened up a bit. I know that is going to change the alternator load somewhat so I am hoping the best blades are still the best blades.
Mike
