Author Topic: winch cable attachment point question  (Read 2201 times)
bennyspoon
« on: June 14, 2011, 12:22:09 AM »
g'day guys,
 i am wondering if there is anything wrong with having the attachment point for the gin pole/winch cable in the anchor rather than on the gin pole itself,with two pulleys for reduction. the reason i ask is that i need to have my winch slightly higher that the gin pole, which would { if attachment was on the pole} mean another pulley and a lot more cable.
any thoughts on this?
cheers,
ben.
wpowokal
Re: winch cable attachment point question
« Reply #1 on: June 14, 2011, 03:03:57 AM »
If this is what you mean then it's OK
Allan of the jungle
Boss
  • http://outfitnm.com
« Reply #2 on: June 14, 2011, 06:33:05 AM »
Nice pics Allan
Brian Rodgers
bennyspoon
« Reply #3 on: June 14, 2011, 08:46:06 PM »
thanks for the reply allan, having trouble replying with my crude rendering, will see how it goes this time, may end up with several!
Fixed pic post for ya :)
« Last Edit: June 15, 2011, 01:52:47 PM by Bruce S »
wpowokal
« Reply #4 on: June 14, 2011, 09:06:44 PM »
Ben what you have drawn is basically what I had, it is not a double reduction but will work just fine.
Allan
bennyspoon
« Reply #5 on: June 14, 2011, 09:17:48 PM »
ok, that's good. there will still be some measure of stress reduction on the components by having these two pulleys though, won't there?
what's the go with the d shackle attachment in the third image allan, is that one that connects from the gin pole to a turnbuckle then your anchor?
cheers,
ben.
wpowokal
« Reply #6 on: June 14, 2011, 09:42:44 PM »
http://www.technologystudent.com/gears1/pulley8.htm a good example.
In my third pic the 'd' shackle and turnbuckle is an anchor rope attached after raising to remove the winch from the equation.
allan
