Remote Living > Lighting
12v ac/dc led clusters
oldmil:
So it doesn't matter which lead gets hooked to + or -? I know the other led's I've messed with had a + and - and would blow out if hooked up incorrectly.
Sorry for my questions but I'm by no means well versed in LED's.
Thanks again.
Oldmil.
dnix71:
I went back to the original list on eBay and the listing does say 12 v ac or dc, so it doesn't matter.
http://www.ebay.com/itm/G4-18-LED-180-Lumen-Cool-White-12V-AC-DC-2-Watt-Bulb-/150647480705?pt=LH_DefaultDomain_0&hash=item23134a2181
It has a symmetric unlabelled bi-pin plug.
http://www.ebay.com/itm/G4-18-LED-Tower-250-Lumen-Cool-White-12V-AC-DC-3-Watt-Boat-Marine-RV-Landscape/151046612021
is a link to a currently available equivalent. It is also labelled ac or dc 12v.
oldmil:
Thanks much for the info.
Hopefully these will serve me as well as they have you.
Oldmil.
tanner0441:
Hi
We used to fit LED panel lights on the computer room AC units the firm I worked for made. They had a cluster of LEDs wired alternate way round, and run them off ac. Diodes are a rectifier and as long as the voltage is not over the breakdown voltage they block the reversed current.
Brian
Mary B:
LED Light Emitting DIODE so they will not croak if reverse voltage is applied unless you exceed its PIV rating.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
