i always use 50/50 spacing
so the space between mags is the same as the mag width.
your second photo looks about right.
can you take a picture of your coil overlaid on the mag rotor?
i'm suggesting a coil with the center hole the same size as your magnets (on average)
the legs the same width as a space .
so the total coil width adds up to three segments, two spaces and a mag width.
giving you a set up where there are 1/2 as many coils as there are poles
that's still single phase .
its tricky to get the mag placement right on a dual rotor when you use a hub with multiple bolts.
when in position, all the mags have to line up with a magnet of opposite polarity on the other rotor
a dual rotor is the optimum setup for flux density.
lots of questions, but if your getting 1.3 volts per coil with a single rotor a second rotor will give you 2.3v ac
x 8 coils gives18.4 volts ac.
x 1.4 for the rectifier=25.7 -1.4 for the diode drop=24.36 open volts.
stick your ugly baby on a 12 volt battery and see if you can pull some amps !
lol
