Hey that 5Ahr 4-by looks great!!
Hows it holding up?
Pretty good...but it need equalizing....some of the stacks
arent like 6.7 ...like one was only 5.43 and another only 5.9
for example and the whole thing read 13.2 as a result after
2hrs. it had dropped down to 11.7 . they seem to get dim
under 12 volts.....but I'm sure they would last a good 2 hrs.
so for 6 hrs 3 or 4 would be good enough.
Okay maybe they'll last 3 hrs. that must have been the bad
one....the one I have on now started at 13.6 and after an 90
minutes its down to 13.24.
that's the one in the kitchen window with about 40 bulbs and so
that's about 4 watts.
Not too bad is it?
Now the set up in the frontroom ....the 12volt SLA 75 amp/hr pedal charged
by my PedGen running a 400 watt inverter to run 50 LED christmas
light in the window....about 4.5 watt according to the box.
battery fully charged run lites for an hour and the voltage drops from 13.6
to 12.9 so I pedal for about 5 minutes at a leisure 30 watts and the voltage
goes up to 15.5 and the inverter cuts off over voltage so I have to slow down
for 5 minutes....(10 min. is about 5 watt/hrs)
I pedal this at a leisurely 40rpm if this where a real bike with a wheel and sprocket
this size I would be traveling 3.5 MPH. in 10 minutes I would travel about .5 mile.
so thats about it.....
for now
Norm.
