I had a bad Lightning Storm a few months ago and it took out 2 Ghurd Dump Controllers and my old 8D battery. I had been experimenting with LongWire power generation and had about 200 feet of wire stretched out like an antenna and connected to the battery through a bridge rectifier.
It was only making enough power to make an LED glow. When Thunderstorms came through, the LED would flash randomly. I thought this setup was fairly harmless so I left it all connected to the battery for a few years. This Summer we had a couple of violent Lightning Storms that came through with huge and loud strikes all around my property. It wasn't long after that I found that my solar power was running low. After investigating I found that my two Ghurd Dump Controllers were blown up and dumping power all the time.
I replaced one of the controllers with a spare that I had, but the battery never did come back right. I looked into the Plastic bin that the battery was in and I noticed evidence that the battery had sprayed liquid from the filler caps and there was even a good amount of liquid in the bottom of the bin. Nothing I did would bring that battery back, so I had to hook a battery charger up to it so I could power the stuff that normally ran off of the battery.
What good is that . . .
Ghurd sent me 2 more Dump Controllers. One was to finish the repairs on my charge controller and the other one is going to be a spare or a Low Voltage Disconnect (LVD). I built both of the controller kits and replaced the second unit in my 2 stage controller. Here is a picture of the 2 new controllers, mounted and working in the charge controller.
Here is a link to the construction of my 2 stage Ghurd Dump Controller
http://fieldlines.com/board/index.php/topic,129731.0.htmlNow for the battery problem. I had a good week at work and enough extra cash to get new batteries for my solar power system.
I was going to go to Costco and get some cheap Golf Cart batteries from there. But I went to my favorite little battery store and found them selling new Trojan T-105 batteries off of a pallet for $118 each. I couldn't resist and I bought two for my 12 volt system at a cost of $254 dollars tax and all. I eagerly got them home and connected to the system. While doing the replacement, I noticed that the old battery had sprayed liquid up about 3 feet on the metal shed walls.
Then guess what . . . 3 days of No Sun . . .
I was so happy when the Sun came out and pushed the batteries up over 14 volts. I got the new controllers set up
Stage 1 - 14.6 volts - 3 amps
Stage 2 - 14.7 volts - 6 amps
Now everything is working wonderfully and plenty of battery power. Ready for the Tornadoes now. The power was off here for 5 days in April 2011 because of bad storms and I was so happy to have my Solar Power.
Oh, and one more thing . . . Don't mess around with Long Wire power generation ! !
