hi thinking I may try getting into a small solar setup 12v bank will these higher voltage panels be OK with mppt or should I look for lower voltage panel.
Model SV-T-205 HV
Power (W) 205 Watts
Open Circuit Voltage (V) 33.10 Voc
Short Circuit Current (A) 8.35 Isc
Maximum Power Voltage (V) 27.90 Vmp
Maximum Power Current (A) 7.36 Imp
Quality Grade Cosmetic Click here to learn more...
Voltage Type High Voltage
Cell Type Poly-Crystalline
Frame Type: Silver
Junction Box: Yes
Weight 39.00 lb ( 17.69 ) Kg
Certifications CE, CETLUS, UL
Warranty 30 Years
At $1 watt its getting closer to fiting into my budget
Thanks Chris
