I know this thread is old but I think my story is relevant. I believe it backs up dnix's post, above. If deemed not relevant, move it to where you want it, or not.
Wife nearly died Sunday Night
It was a typical Rainy season night. Medium density rain falling,
little bit of wind, and the sound of thunder in the distance. Wife
was preparing clothes to be ironed.
Instead, she decided to make hot chocolate for us. I had already
disconnected all the electronics from the outlets, computer, modem,
UPS, television, and amplifers from the external antenna, outside.
Lights were blinking, as usual, and we were as content as possible.
I was sitting in my favorite chair at the computer desk, when, SNAP
lightning hit something, DAMN close. Wife yelped, as usual, and I
turned and looked at her. She was standing by the stack of clothes piled
on a bar stool type chair I had built, and the house was filling with
the odor of burnt plastic and ozone. I grabbed a flashlight and started
searching for smoke or fire. Wife was kinda slumped on the stack of clothes
and seemed fine, so, I went out the back door and looked toward the shop.
All was dark, no fire. Came back in the house and wife was slumping more toward
the floor and had moved about 6 feet to another chair, presumably to sit in.
She was making weird sounds and having trouble breathing. Then, she slid down toward
the floor and caught her chin on the chair and was choking. I grabbed her and
it was like trying to move a sack of water. Limp as could be. She had 1 foot caught
in the toe kick of a portable island cabinet I built, and I had quite a time getting
it loose.
Finally, I had her propped against the base cabinets in the kitchen and sitting on
the floor.She had difficulty breathing and heart was beating probably just below fibrillation.
I ran to check more areas as the odor was very strong and I suspected to find fire, somewhere.
Ran back to check on wife and she was in dire straits. I moved/dragged her into the living room
and managed to get her on the sofa.She only weighs 95 pounds, but, being limp, felt like 500
pounds. Went to the phone to call for help and, of course, it was dead. Went back and wife was breathing a little
easier,and heart rate was down some. She has a valve problem as it is.
After a bit she was not comfortable, so, wanted to get on her rocking chair. Don't think THAT wasn't a fun deal.
Anyway, an hour or so later, I talked her into laying on the bed, to reduce pressure from sitting. She was hurting
badly and arms and legs wouldn't work. So, I got her up and dragged her into the bedroom and onto the bed.
Took a final look all around, and, finding NO smoke, sat down to catch my breath. Kept checking on her throughout
the night and she is still recovering. Turns out, she was in the fridge and had reached out to close the door when
she was zapped by the lightning strike. This is in the middle of the house, roughly. She said yesterday, she was lifted
off the floor and saw an arc oflightning jump between her knees. There is no sign of burning
anywhere on her. She is mostly fine, just weak as water.
Yesterday, I went outside and checked all the wires, especially the phone line. Everything is fine. What the hell ??
Happened to glance over at the TV antenna, and could not make out the co/ax going from the metal pole to the house.
Went and took a better look, and, the section of co/ax, about 6' long, was laying on the ground. Lightning had hit it somethere
and burned it off at the pole and at the roofline of the house.We just put a new metal roof on this summer. There is a hole
in the metal roof that I could probably stick a pencil through, and the section of cable was burned in 3 areas. I went in the house
and pulled the pre amp out from behind the brand new TV, and saw soot on the table/shelf. The pre amp was burned up inside.
Now, all you engineers and such, how the hell did lightning get from there, to about 18' away with no cable in the area, and strike the wife
I'm thinking it was a big static charge, but, why from the fridge and to her through the cement/ceramic tile floor ??
