Fabricator
I just looked up the doc wattson meter. $59 bucks, am I looking at the right thing?
http://www.powerwerx.com/digital-meters/doc-wattson-meter-dc-inline.html
Does this also need a shunt? Does a guy need two of these, one to show the battery state and one to see what the turbines are doing?
Thank you
gww
Yep that's what we are talking about, that unit has a constant battery state meter, in the bottom left corner it alternates readings of kWh, and two other readings I can't remember right now, somewhere on that site they sell the external shunts also, on the actual DocWatson site they tell you how to hook it up.
To dump power on the ac side you need something like the morningstar RD1 relay driver, you connect the AC side of your inverter to one side of a normally open relay, to the other side you connect your load whatever you want to use, a space heater, the elements in a water heater, whatever.
The relay driver is connected to the batteries and you program it to do whatever you want it to do, you do need a pc or a laptop to program that unit, the output from the relay driver gets hooked to the coil of the big relay, when the parameters you put in it are met it energizes the relay coil and dumps ac to your load, when the low end parameter is met the driver turns off.
