Author Topic: how many watts produce a 24 magnet & 12 coils  (Read 2522 times)
kil1800
  • Country: do
« on: October 31, 2012, 01:58:51 PM »
hi this is my first post, I'm trying to make a wind turbine but I have a question, how many watts produce a turbine with 24 magnets and 12 coils like the one shown in youtube videos using a disc brake 11 inch I need to get at least 500 watts please indicate how to get it if the 24 magnets and 12 coils do not produce it, if I have to use more than magnets and more coils. Thanks
gww
Re: how many watts produce a 24 magnet & 12 coils
« Reply #1 on: October 31, 2012, 04:02:20 PM »
Have you looked over the volvo disk break projects on this web site?
gww
fabricator
  • My smoke got out again
« Reply #2 on: October 31, 2012, 06:58:14 PM »
Everything depends on how hard the wind blows, brake drum mills are pretty much old technology now, a dual rotor axial flux machine will make more power with less wire and magnets.
prasadbodas2000
  • Country: in
« Reply #3 on: November 01, 2012, 03:14:45 AM »
If we keep the wind availability aside (meaning that we assume it to be a very good windy site) and just want to determine practical max power such a machine can make, even then magnet size and grade,  rotor diameter, coil wire size/guage will be governing factors....
And as such a correctly designed, sized and fabricated dual disk rotor generator with 24 numbers (12 on each rotor) 2x1x0.5 inch Grade 35 Neo magnets can go for 350-500 watts sustained output....IMHO
« Reply #4 on: November 01, 2012, 08:24:06 AM »
 Pick up the two books the one from other power and the Piggot book . The Disks are heavy  but it's all doable . You'll find though that
Trailer parts and two steel disks make a more reliable hardware match . There are bolt on spindles and if you send your hub pattern to Otherpower or Windstuff you can get a match for  around $100 with jacking screw holes and the whole 9 .  Take a step back and save some money tat will save money in the long run . start by picking up some batteries and solar in the mean time .
It would help if OP would post the bolt parttern in PGF hint hint
« Last Edit: November 01, 2012, 08:46:25 AM by tecker »
fabricator
« Reply #5 on: November 01, 2012, 09:14:32 AM »
With the machine you describe just a wild estimation with the correctly sized wire would be a 1kW sustained machine.
kil1800
  • Country: do
« Reply #6 on: November 01, 2012, 11:53:45 AM »
First, thank you for taking your time to read and answer my post. Could you tell me where or how to get this new technology you mention. Thanks
kil1800
  • Country: do
« Reply #7 on: November 01, 2012, 11:57:40 AM »
gww
Not but I will thank you.
fabricator
« Reply #8 on: November 01, 2012, 01:42:09 PM »
Just go to the top right hand corner of the pager and click on the other power logo, then on the site click on wind power, it's all there.
