Author Topic: Number of turns for 2-coil 24v stator?  (Read 4349 times)
fordfasterr
« on: January 11, 2013, 10:24:23 AM »
Hi all, I have been working on a project to build a small generator out of a spin bike that I ride at home.
I have the strong magnets, however they are quite small (about the size of a dime, but twice as thick) so I need to build some small coils.
Anyway, I need to know how many turns to put on each coil to get about 24-30 volts.  I will then rectify it as usual. I have 400 feet of 24 awg green magnet wire. (I hope this will work!)
If the first two coils work, and I get a voltage  then I will simply build 2 more coils and wire them in parallel to keep the 24 volts using a 2nd rectifier.  I might even build a 3rd to see if I can still keep the thing moving with more load..
Can anyone chime in, PS: This is my very first generator build.
( I have a 24-36v grid tie inverter with a dump-load connection that I will be connecting to the generator) ...
Re: Number of turns for 2-coil 24v stator?
« Reply #1 on: January 11, 2013, 11:31:23 PM »
what kind of alt are you trying to build ?
dual rotors-single ?
2 coils? 4 coils? or 6 coils?
you  could just build a simple single phase alt--ide go with at least 8 coils...
maybe 80 winds per coil--8 mags per rotor.........hard to tell what you have planed...?  just a guess your going to put the mags on the bike rim and coils off to the side-top ?  might want to double stack those mags for a little extra power..
good luck.........
fordfasterr
« Reply #2 on: January 13, 2013, 03:03:15 PM »
Here are the pictures of the spin bike rig:
I still don't know how many turns to put on each coil to get +/-24vcd after rectification.
« Reply #3 on: January 13, 2013, 03:15:01 PM »
I see room for a 12 magnet 9 coil setup, could be one or two sided. Is the bike wheel made from steel?
fordfasterr
« Reply #4 on: January 13, 2013, 03:16:04 PM »
Answer to post above:  yes, it is made of steel.
I really should be more clear as to what I actually need help with.
My best guess is that the easiest thing to do here for starters is to simply create a single coil, wind it up x # of turns and then test it out...
Based on the results, I can add/remove more turns as needed to get the the right number of turns necessary.
Of course you don't see the magnets on here yet... I'm waiting to position them once I have somewhat of a decent coil assembled..
« Reply #5 on: January 13, 2013, 07:23:33 PM »
heres a simple setup up...used auto flat belt---mounted on the flywheel down
to any dc or ac motor you might have--you can make a pully from plywood
to get the right gear ratio...good luck  ....
                   http://www.youtube.com/watch?v=iC9op-nWxPE
fordfasterr
« Reply #6 on: January 14, 2013, 08:33:58 AM »
I have considered the idea, but then how will I learn more about generators?
It would be of much more value to me if I made it myself from scratch rather than strapping a belt to a generator.
Another option I was thinking about could be to arrange the magnets so that they produce only DC power.  iE, face all of the magnets in just one polar direction so that I don't have to run the coils through a bridge rectifier.
What do you the experts here have to say about this approach?
« Last Edit: January 14, 2013, 09:06:14 AM by fordfasterr »
« Reply #7 on: January 14, 2013, 02:25:21 PM »
I would mount 12 magnets on the wheel, wind 12 coils and mount it as close as possible. Won't be very efficient but you would learn a lot. Look at the axial air core alternator in the wind section for ideas.
« Reply #8 on: January 14, 2013, 06:58:51 PM »
heres a old 8 and 6 dual rotor alt i made years ago--coils wound from plastic coated wire-not mag wire..  cheap ceramic mags...
6 coils 8 mags per rotor 3 phase...fun stuff
i really dont think your going to get any real power from your little mags mounted on the flywheel- with coils mounted above..are you going to mount the coils on some kind of steel band--or not...the steel will attract more of the magnetic field up to the coils[more power output]--but will also induce some drag as well..
had the same idea awhile back--was going to use ceramic mags doubled up[side by side]..and some sort of steel backing for the coils..  well have fun..its always a blast to see your own cereation come to life.....  ITS ALIVE........................
    http://www.youtube.com/watch?v=LSdOwSBXKGg
