"I understand that when 3 sets of coils are properly arranged and wired together in 3ph, the output is 1.7 x the output of a single coil , so
47.16 * 1.7 = 80.17 V 3ph RMS if wired star.
Then if I wire that in delta, it's *1.7 again?
80.17 * 1.7 = 136v
? Does this sound right?
No It does not sound right. The delta will be your 1 phase voltage, and star will be delta X 1.7
So if a single phase put out say 10vac, then Delta will be the same. If you look at delta, it has three phases all delivering different potential at the same time.... but the Max V will still only be the voltage of a single phase group. ( current will be more in delta then single phase obviously )
If you look at star, you will notice your EMF is gotten from two single phase windings in series...... but mechanically/electrically out of phase by 120 degrees. The vector addition will be 1.7 X the EMF of a single phase..... ie 10v X 1.7= 17vac
The DC voltage will be your AC voltage X 1.414. This is because you get to have the peaks as your V max. .... so 17vac X 1.414 or 24vdc. for star or 10X1.414 for delta or 14vdc. These peak volts will be where you start to charge the battery....... but this is the peaks only.
If you look at your countries three phase to single phase voltages you will see the same thing. Here we are 240vac 50hz for single phase. Our three phase is 415v If we divide the 415v/240v we get 1.7..... so from phase to phase we get 415vac from phase to neutral we get 240vac.
A practical example is... if we have a star wired motor for 415v, if we wire it delta, it will be nominally a 240v three phase motor........ so we can now use a VFD single to three phase converter and drive what was a 415vac three phase induction motor as a 240v three phase variable frequency motor.... or as I do, make a phase converter from single to three phase 240vac using caps and a three phase motor as a rotatory converter, and drive 415v star motors as 240v delta motors ( in my milling machine and brake press)... so it does work in the real world too.
As for the "hugh V's Lenze".....
For any given RPM and flux density, it is only the number of turns being cut by the changing field that vectorially add up to the output voltage. It does not matter which system you use. The interleave will allow for slightly better stacking of your after sheer power density, but for the room you seem to have, maybe that is not so important.
If you want higher voltage, simply use more turns per coil number. When space is at a premium, this will mean smaller wire to get the same mass of copper into the same space..... our resistance will increase with each extra turn, and with each smaller wire diameter we go to.... nothing is for nothing.
So the only advantage the interleave may have is that you may get the resistance down for the SAME number of turns.... but that is all you can achieve with it. The difference has been found to be not worth the extra effort, and crowding the magnets, and squeezing the coils a bit seems to make them on a bit of a par for my money.
Hopefully Flux will intervene and set us both straight. Chris Olsen has done some fine work with both serpentine, interleaved and standard. As I understand it, he runs standard 3:4 for the best results, with the least effort. He is a perfectionist, and no doubt will have done a very careful analysis of all systems before committing to only one of them..... and may have more to add..
In short ......the total turns per phase = voltage.... ( for the same number of RPM and flux density.) Current is regulated by the resistance and your threshold for pain with heat.
Providing you have the forcing voltage to achieve it, any wire will support any current for a finite time. 1000A through wire the thickness of a human hair will have a voltage drop of V=IxR..... and that drop X current will be the watts lost in that circuit.... survival will be measured in nano seconds before the circuit breaks (vaporises), but a 3" busbar will support it indefinitely as the voltage drop will be very small.
Now we can see why we try to keep the R down in the stator....... but we do need R in the stator to allow for not stalling the rotor. If we could wind with no resistance, the prop will never go past cut in, as the zero loss stator will stall it at that point...... so we need a bit of everything, some voltage and some resistance ( unless using an MPPT converter) to make the system work properly.
All a bit of a symphony really
.................oztules
