For better answers we'll need a little more info.
When you hooked up the drill at what speed (RPM) did it start to light the light?
What was the volts as well?
These are important, as they will determine whether or not it'll be a good candidate for wind.
High speeds can be hard to obtain depending on the setup and style of blades.
You'll need about 14Vdc so taking the 1V/24RPM info that's about 340RPMs, while not that hard to obtain can be depending on again the blades and the site you are looking to use, plus the average wind speeds for that site are very important.
While the light bulb is a good quick way to see if it'll possible work , we'd also need to know what the wattage of the bulb is, standard for a 1156 single car bulb is about 55watts.
Hope this helps
